magnum takes 360 mounts I believe. We just use Schumacher so havent tired factory la stuff.anyone using spool mounts on a magnum motor?, I am putting a 5.2 magnum in a 73 dart ,can I use my old spool mounts or do I need different mounts . THANKS FOR ANY INFO
Best you pm us and get the phone # so you can talk to J. He deals with all the web site/sales stuff. I deal with wire harnesses, pcm flashes, cam design and fuel system design. We will be in shop after 9 am pacific timewhich shumacher mounts /6 to small block or 273-360 replacement mounts ? and year range must vary for car your using , just trying to pin down before buying new mounts thanks
thats correct, we have them on the shelf and can probably make a special deal for FABO on those but you would have to call and talk to J, he does all the pricing and web stuff. magnummopar.273/318 take different mounts then 340/360. If you have a set off a 340/360 LA motor then you're good, as all Magnums take that style. If you have 273/318, you'll need new mounts.
If you look at the Schumacher site for slant 6 to small block V8 conversion mounts, they list one for the 273/318 and a different one for 340/360.
