Magnum Valiant
Will someone please tell me if these mounts are positioned correctly for installation in 64 Valiant?
Thanks 66. After some cutting and welding, I am now able to use all holes in engine block mount ears.Looks correct to me.
The brackets mount behind the block tabs and the lip is up.
I used Gabe's trick in the Magnum swap"how-to" on the passenger side. Used a length of all- thread with washers and nuts on all sides.
Diy - Magnum Swap!!
You should be able to used all the bolts on the driver's side.
On my 66 Barracuda I had to grind some on the driver's side block to get the starter to seat correctly and had to grind some off the truck mount to clear power steering gear.
5.2 Magnum bored .030, EQ heads, Voodoo cam, Street Demon on an air gap, Magnum xmanis. 64 Valiant, sitting since 1987.Nice work!!!
What are your plans for your engine? From your screen name sounds like it's going in a Valiant??
