magnumforce drop spindles
737jetdr
Martinsville, In.
Is anyone running a set of the magnumforce drop spindles on their A body? If so do you have any pics? I was thinking about buying a set but not sure exactly how low the car will sit. probably have to modify the rear too. I have a set of the drop brackets for the rear leafs from Magnum Hp but I have a feeling that I might have to use a 1" drop block too to get it to look right.
