magnum's
moparmaddnes
Member
Austin MN
I have been thinking about puting in a 360 magnum (? liter) motor in my demon, but dan't know when they started the magnum series? My thought on this is for the roller system in the motor. I have a 73' 340 that needs crank and full rebuild so I thought that the magnum's would be a better way to go and down the road I could put a stroker set-up in it. Opinions on options would be greatly appreciated. THANKS
1992 - Magnum appears on 3.9 v6 and 318 v8 (5.2)
1993 - Magnum 360 (5.9) appears
I have a 91 Dakota that has the la 318 in it, so this info should be correct. But it could be possible they could have made a 360 magnum under a hood some where.
