main harness under dash removal?
sdwolff98
Member
plano texas
Hey Guys,
I am removing the entire underdash harness assembly. Got most everything disconnected except where the main harness goes through the firewall. Ho do I get the copper tabs to relase it so it will drop out and I can finish removing it for some working over and refreshing connectors n such?
1970 dodge dart swinger.
Thanks
Sean Wolff
here is a picture of what I am trying to get out..
Thanks
Sean
push the big clips in.....it just snaps in...
Ok got to looking at it and used a pair of needle nose pliers and the bulkhead popped right out. After about an hours work had the harness stripped and got a good look at it. The wires underneath the tape were in fatastic shape. I have one broken section on the driverside circuit board that will need some field expedient repairs to get it working again. Pics below
Sean
