Making a carbon fiber package tray
blue missile
Austin Texas
There was some interest in carbon fiber composites in this catagory. I actually had two consecutive days off to work on this, so I thought you guys might be interested.
I know making a package tray is a basic deal, but this one has a built in full width third brake light.
First I took the original one, which was disintergrating, and transfered the pattern onto 1/4" ply. I then figured out what it was going to take to get the light visible above the bottom windsheild gasket elevation wise.
I attached a series of blocks in the needed arch to create the base of the light.
Since I already have the perf board that I am making the LED strips out of, I added the hight of the strip and attached a 1/4" back to the arc.
I then cut another piece of 1/4"ply to make the transition and create the top of the light. Fastned it on and bondo'd the seam.
I cut the carbon and dry fitted it to the piece, pre cut the peel ply and the bleeder cloth and made the bag out of 3mil poly. I then mixed and applied the epoxy, put on the peel ply and bleeder cloth. Sealed up the bag and evacuated the assembly. Five hours later I stripped the bag and plys off and trimmed the excess fabric while the composite was still a little flexible.
Pictures are included.
Andrew
The 1/4" ply remains, Dont know if I'm cutting speaker holes, a thin sheet of carbon would tend to crack at the attachment points and a 1/4" of carbon is alot of plys.Figure 8-10 plys would do it. Figure $8-$10 per sq ft per ply.
Andrew
Just thought you guys would like to see rear light lit up. I just got half of the leds for proof of concept. Ill get the rest later.
Oh by the way I know you guys will scold me but yes it does light up in red and blue to be selected at the switch panel in the console.
Andrew
Hey, Blue, nice look. How do you determine how much resistance to put into the circuit to light the LEDs?
VERY NICE ! Blue might be illegal in many states.
OK
illeagal mabey thats why its switchable.
As far as the circuit requirements, I cheated. I bought 9" strips at harbor freight already set up for 12 volts. Past that I think its around 250 ohms per led.
I actually have to sit down and write part ninteen but it will be there soon. I am glad to see that it is entertaining some of you.
Once I get past that part all of these posts will be continued over there under the continuing build. If you think this is mad engineering you aint seen nothing yet!:toothy10:
Andrew:glasses9:
