Marlabuck
Thanks guys for all the help on the problem I recently had concerning a burned fuseable link wire...I believe that what happened was while I was changing the dash bulbs to LED's when I positioned the dash cluster back to check all the lights, when I hooked the battery back up I moved the dash a wiggle bit and I think the positive connector on the back of the dash hit some metal...anyway, found the dead wire and like the member said it would appear as limp spaghetti and it was...it was limper than my first husband's...well, never mind. I ordered a Packard connector and a got a fuseable link wire and as suggested will connect this wire to a fused in wire...the connector housing on the bulkhead has some corrosion going on and I will address that too...think I got all my ducks in a row and hopefully by Thursday I can get the car back in shape...my car is a 1975 Scamp...Marla
