stroker402
1968 dart GTS convertible
I have a mallory 11K tach with shift lite and rev. limiter .. has 4 wires on it to hook up.
Green coil neg.
red 12v source ,
black ground
white lite.
hooked it all up to these instructions and when I hook the green coil wire up it will kill the engine..
I am running a oem mopar dual point dist.
what do you think the problem might be ? maybe needs a tach adapter ?
or just won't work with a points dist.?
Thanks for any help.
john
Green coil neg.
red 12v source ,
black ground
white lite.
john
