Hyper Henry
Mallory part #3140 fuel filter
The 140 Series Comp Filter is designed for the high performance enthusiast who knows the importance of always ensuring that there is a fuel filter between the fuel tank and the electric fuel pump. The 140 Series of Filters is designed for use with the Mallory COMP PUMP® 40, 70, 110 and 140 Series of Electric Fuel Pumps. The 140 Series of Filters are perfect for those engines which require a maximum flow, minimum restriction filter. The 140 Series of Filters employs aircraft quality manufacturing techniques and advance component design that can only come from the industrys leader in high performance. An integral mounting bracket is provided for easy installation in almost any application. The filter element is replaceable and the filter canister unscrews readily for easy servicing of the filter unit.
Specifications: Two inlets and two outlets: 3/8'' NPT.
Service Parts: 650-3141 - Replacement fuel filter element and o-ring. Also fits Mallory 500 Series Comp Filter Fuel Filters.
excellent condition $60 with free shipping.
