Hi all. I recently installed mancini's XHD leaves in the rear and now one side sits lower than the other. Funny thing is, it's the passenger side that sits lower and it is about a 2" difference. Mancini said the DRIVER'S side should sit lower by about 1" but that you can adjust the front Left torsion bar to accomodate this.
Well I have a question. They have an 81 and an 82 painted on them, and we put them on in the way that they were listed on the invoice. (I think 82 is on the right but I'm not 100% and I'm not at the car right now.) Anywho, I called them and they said it should appear that one side has more leaves forward of the axle and that that leaf spring should be on the passenger side. Looking at what we did (according to the numbers they painted on the springs) we have that reversed.
So what's the deal here? How do I get it to sit even? Which spring goes on which side???
Also, is there any way to get a little more lift out of them without adding a leaf or anything? I'd just like it to sit a little bit higher. Thanks.
-mccula
-mccula
