dartsport73 Well-Known Member Joined Nov 2, 2010 Messages 46 Reaction score 0 Location Maryland Nov 13, 2010 #1 Is there a preferred method for cleaning exhaust manifolds and intake manifolds? Rust on the outside, carbon build up on the inside.
1968FormulaS340 Well-Known Member Joined Aug 24, 2005 Messages 11,394 Reaction score 707 Location St. Helens Oregon Nov 13, 2010 #2 Hot tank or sand blasting.
Murray FABO Gold Member FABO Gold Member Joined Apr 19, 2010 Messages 3,992 Reaction score 3,266 Location San Jose, California Nov 28, 2010 #3 Bead/ sand blasting is the only way to go. I use Eastwoods high temp exhaust manifold paint, pick your color. Will cure when engine fires. No paint, it will rust.
matthon Well-Known Member Joined Aug 29, 2008 Messages 3,046 Reaction score 1,433 Nov 28, 2010 #4 Evaporust I think its called- it might work well on exhaust manifolds, but you may have to buy alot of it.
