Manifold Crack Question
65Valiant310
Will this eventually crack? Going to install yet wanted to see what you all thought, as there is a grind/scuff mark pretty large highlighted in yellow.
thanks!
I wouldnt think it would crack. Looks like a smooth burr. I'de run em' as is & try repair IF/when needed.
Naw, it probably won't. If you're really that worried about it, you might take and knock any sharp edges down with a file if there are any.
