Manifold heat riser - keep or remove?
Rocket
CT
Has anyone removed the heat riser from their stock 340 manifolds? Can this be done in a way that it could be put back on later if required? How did you clock the holes in the manifold afterward? Any performance gain in doing so to make it worth while?
Thanks
