[Found!] Manual Brake Pushrod
I need a manual brake Pushrod. I was trying to remove mine from the old master cylinder and it just sheared.
PayPal ready.
just put your master cylinder in the Bench vise and pull the rod with a vise grip and a Hammer,,you can ad some loose nut on the end of the push rod
Too late... I trieded to pry it out (after yanking on it with vise grips) and it just sheared.
