What are you guys recommendations on replacing steering box. Mine is feeling loose, not sure which direction to go.
Have you tried adjusting yours first? There is an adjustment nut on top. Might as well give that a shot before spending money. Unless you're just wanting something different.
Every thing front suspension wise is new. Steering box and column only thing leftThis.
And also, is everything in your steering linkage/suspension new? Because if your tie rod ends, pitman, idler or steering coupler are worn it will feel the same as play in the steering box.
