74Dusted
Stock Piler of 340's
The column shaft from a Manual Steering 3 On The Tree column fits in a Power Steering Floorshift Column, right?
I have a '71 Floorshift Column in my '74, and as much as I love the Power Steering, I need the room for headers.
I have a Manual Column in my '71 Duster, and thought I'd just swap the shaft. It's not the first time I've installed a shaft in the column in my '74. When I bought the column, it had no shaft, so I transplanted the shaft from the original out of my car (Auto on the Tree, Power).
I can use the Steering Box from the '71 as well, correct? Or is there something that would prevent me from using it? I know the mounting bolt pattern is the same, and with the column shaft from the same car it should drop right in?
Is there anything I'm forgetting?
