manual trans with 5.9 magnum
Manual Transmission & Clutch Discussions
  1. duster george
    duster george Member
    8
    0
    Jun 19, 2011
    mo
    Local Time:
    2:44 AM
    need help have 5.9 mag out of 98 dodge 4x4 have complete truck .putting it. n 71 duster was slant 6 3 speed on floor .what trans needed just a cruiser .would like to keep efi stock from truck if possible
  2. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    64,439
    37383
    Jun 7, 2010
    Georgia
    Local Time:
    3:44 AM
    Put the three speed behind it.
    • Agree Agree x 2
    • Like Like x 1
    • DionR
      DionR Well-Known Member
      2,104
      253
      May 7, 2008
      Spokane, WA
      Local Time:
      12:44 AM
      If you want to keep the EFI and the manual trans, you will need an aftermarket flywheel. The flywheel has the crank tone ring notches the PCM uses to know the crank rotation and the stock Magnum flywheel is too large for a car bellhousing. I know of one guy that had one turned down to fit the car starter ring, but seems hit and miss as to getting a shop to do this.
      You will also need a different bellhousing to bolt up to your 3 speed. This bellhousing will require a notch to be added for the crank position sensor as well.
      In the end, it might be easier all around to find a small block 904/727 and use that if all you want is a cruiser. Unless you really want to use a stick.
    • dodge71demon
      dodge71demon Well-Known Member
      3,383
      521
      Apr 29, 2009
      Indiana
      Local Time:
      3:44 AM
      change the manifold and use either the fitech or sniper efi or use an automatic either way IMO your opening a can of worms remember the balance on the magnum is different than any thing else
    • RustyRatRod
      64,439
      37383
      Jun 7, 2010
      Georgia
      Local Time:
      3:44 AM
      Whatever happened to real hot rodding? Yeah, just give up. That's the answer.
      • Agree Agree x 3
      • Like Like x 2
      • dodge71demon
        3,383
        521
        Apr 29, 2009
        Indiana
        Local Time:
        3:44 AM
        If your replying to my response I'll be nice I've probably done more HOT RODDING than most people on this site
      • RustyRatRod
        64,439
        37383
        Jun 7, 2010
        Georgia
        Local Time:
        3:44 AM
        Not replying to any response in general. Just the general attitude of giving up an idea because it's "too hard".
        • Like Like x 2
        • Syleng1
          Syleng1 Karma is real and Life is short... FABO Gold Member
          1,865
          1440
          Jul 5, 2005
          North Franklin, CT
          Local Time:
          3:44 AM
          :popcorn::popcorn::popcorn:
        • TT5.9mag
          TT5.9mag Two atmospheres are better than one
          560
          541
          May 5, 2016
          So cal
          Local Time:
          12:44 AM
          If you want to keep the original efi the only real option is to use a Bellhousing and flywheel from a manual trans equipped Dakota or Ram. The Dakota was offered with an AX15 5 speed trans behind a 3.9 v6 and the Ram had the nv3500/4500 5 speeds. It is possible to find the stuff on eBay occasionally if this is the route you want to go.
        • duster george
          8
          0
          Jun 19, 2011
          mo
          Local Time:
          2:44 AM
          would a Dakota 4.7 with manual work its 2003 I think
        • TT5.9mag
          560
          541
          May 5, 2016
          So cal
          Local Time:
          12:44 AM
          Don’t quote me because I have no first hand knowledge of the 4.7 but I think the Bellhousing bolt patterns are different.
        • duster george
          8
          0
          Jun 19, 2011
          mo
          Local Time:
          2:44 AM
          what's benefits of 904/727 verse stock 2wd drive truck trans ? are they smaller?
        • Tooljunkie
          Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
          15,670
          15241
          Jul 22, 2017
          Manitoba
          Local Time:
          2:44 AM
          Think i would transplant a 4.7. They run pretty strong. And Less money to maintain than a 5.7 hemi.
          I have a 360 magnum /manual i was considering putting in my barracuda. I have been wrenching all my life, and after researching it i thought different.
          Good luck whatever path you choose, interested in seeing the build.
        • dartslantsix
          dartslantsix Well-Known Member
          146
          36
          Mar 3, 2011
          Klamath Falls, OR
          Local Time:
          12:44 AM
          I'm using an AX15 in my car behind a 5.2L with stock injection. It's been fine, but did require substantial tunnel mods. The torsion bar cross member had to be opened up and the sheetmetal redone. Details are on my blog www.dartslantsix.wordpress.com
        • GREEN DART 5
          GREEN DART 5 Well-Known Member
          92
          72
          May 31, 2017
          NOR-CAL
          Local Time:
          12:44 AM
          I think American Powertrain still makes a flywheel that will work with the ignition trigger. Part number FWCH-10004CS. Then it’s a small cut/notch in the bellhousing and mount the trigger. This was for a 4 speed.....the cost of the flywheel with my laziness lead me to put a carburetor on.....Good luck with your build!!!!!
        • 67Dart273
          67Dart273 FABO Gold Member FABO Gold Member
          44,989
          12581
          Oct 14, 2010
          Idaho
          Local Time:
          12:44 AM
          On top of the other problems, "duster george", was this an automatic or stick originally? My old gas 5.9 2500 HAD NO PILOT DRILLING with an automatic. You would have to either have the crank machined for a pilot, or hand drill a clearance hole for the pilot shaft, then use the large diameter pilot bearing/ fits in the pilot hole.
          There has GOT to be a way to trigger that thing, even if you have to build your own trigger wheel, either at the front or rear of engine.
          So far as balance, don't know. Surely the aftermarket makes 5.9 flywheels for pass. car bells. (130? tooth)
        • sireland67
          sireland67 FABO Gold Member FABO Gold Member
          9,287
          3476
          Oct 27, 2010
          WV
          Local Time:
          3:44 AM
          My 5.9 was drilled for a pilot bearing.
          McLeod sells a 130 tooth flywheel that takes a bolt on weight for the mag balance.
          As far a FI not sure, I ran a carb on mine.
        • duster george
          8
          0
          Jun 19, 2011
          mo
          Local Time:
          2:44 AM
          what bellhousing and trans u use
        • sireland67
          9,287
          3476
          Oct 27, 2010
          WV
          Local Time:
          3:44 AM
          I have done it twice.
          Stock bellhousing 833 trans (car)
          Stock bellhousing NP435 trans (truck)
          Both times used stock type flywheel from McLeod with bolt on weight.
        • MRGTX
          MRGTX Well-Known Member
          1,893
          711
          Sep 24, 2007
          CT, USA
          Local Time:
          2:44 AM
          Why are some drilled and some not? Is it only Magnums that were installed at the factory with a manual transmission that are drilled? How about Mopar crate engines?
        • sireland67
          9,287
          3476
          Oct 27, 2010
          WV
          Local Time:
          3:44 AM
          I don’t know why.
          Right now I have two 1972 340’s both with a cast crank, one is drilled and the other one is not.
          • Thanks! Thanks! x 1
          • Idaho
            Idaho FABO Gold Member FABO Gold Member
            2,601
            257
            Oct 17, 2006
            Local Time:
            12:44 AM
            The flywheel for a 5.9 will cost around $350 IIRC.
            I’m doing this with an A833 OD.
            Bought the flywheel then decided to make it a stroker (internally balanced) so will be selling the flywheel.
          • TripleL
            TripleL Well-Known Member
            126
            61
            Nov 11, 2019
            Ohio
            Local Time:
            3:44 AM
