Map light
moparker
I have a factory map light with all the wiring in tact from a 71 Valiant. I want to put it in my 71 Duster which didn't have one from the factory. I thought it would just plug into theexisting harness jack but, I can't find one that fits. Was the harness equuiped to take the map light or was there a seperate harness for these all together.
It plugs into the passenger door switch wire, I'm not sure if there is a plug there or if you have to unplug it and plug the map light into the harness.
This is speaking from 67 a body experience.
Here is a pic of a 67 dash with the map light. I can check mine later if no one else chimes in.
I'll try that when I can get to my car. It is buried! I hate winter. That would make sense that it would plug into the pass. side door switch. When I unhooked it came from that side. There is another plug that seems to plug in towards the center of the dash also. Thanks for the help. I'll grab my light and post a pic tomorow.
