zhandfull
As I'm gathering parts to load in the trailer. I thought I would give the local guys and gals first dibs here on the FABO forum. To score some of my parts. I will take paypal for parts paid for prior to the event. Pick up can be in person in Rancho Cucamonga, CA prior to the event or at Spring Fling on April 16, 2011
After the event I may be open to selling and shipping out parts to others that can't do a local pick up or attended the Woodley Park Spring Fling on April 16th 2011.
Please don't respond to this thread with questions as I will be adding parts every couple days prior to the event. Send all questions or inquiries by pm or email to [email protected] and it will make this thread much easier to view for all with interest.
First off I have the following.
Small bolt pattern 15" X 4" Ansen Sprint Wheels slot mags never used but bought from another member here on the site seem to be in nice condition could maybe use a little polishing no caps with wheels. $200.00 for the set of 2
Small bolt pattern 15" X 3.5" Centerlines nice driver condition with caps could be show with a polishing job. 1 wheel was leaking air so I resealed the wheel haven't tried mounting tire to check if it was fixed. That is a pretty common problem with these skinny Centerlines. $200.00 for set of 2
Small bolt pattern 15" X 7" Centerline wheels without caps 4-7/8" advertised backspacing to inside edge of wheel not inside tire seat as some manufactures use. Good driver condition could be show with a little polishing. These wheels work very nice on early Darts, Valiants, Barracudas, and 67 and later Darts with the lower lip rear fenders. $300.00 for the set of 2 with 235/70/15 used tires street tires ok condition.
Large bolt pattern 15" X 10-3/4" wide Centerline no caps. That is measured from inside bead to bead. Backspacing is 7-1/8" laying a strait edge across the back of the wheel. These wheels are drilled for tire screws condition is good. Would be ideal for cars with the leaf springs relocated under frame and mini tubed. $200.00 set of 2
Large bolt patten 15" X 14" wide Centerline no caps. Back spacing is 7-1/8" laying a strait edge across back of wheel. These wheels need a good polishing as they aren't cleaning up very easily with my mothers power ball. in the pictures you will see I have one wheel partially polished up, The other I will work on but they really need a professsional polish to look like new. $200.00 for the set of 2. Perfect for pro street or race car.
Mickey Thompson Sportsman front runners 28" X 7.50". Tires are pretty old 5+ years but look fantastic no crack or ageing is seen, tread is probably 75%
$100.00 for the set of 2
Edlebrock 120GPH electric fuel pump almost new I took off to install mechanical pump $100.00
Thanks
Mark
More later!
Thanks
Mark
More later!
