master cylinder push rod
jazak5
NY
I have
69 barracuda 10 inch non power drum / drum
can I use the same push rod for my KH front non power disk conversion ??
or do I need a different one and where could I find one ??
I think that Mancini has an adjustable one, and you may asked them about the length you need.
There the same. I have several from all cars drum and disc they are the same.
I'm switching from 4 wheel drum to 4 wheel disc. I'm using a newer style aluminum master with an adapter plate to the firewall. My stock pushrod is the correct length for this setup as well.
