What year master cylinders will work on my 65 dart? I currently have the single reservoir and will be changing my front brakes to disc soon, and would like to update the master cylinder.
go for a 73-76 dart with disc for manual brakes so that you get the little rubber pushrod retaining piece. run a new line from the master thru an adjustable prop valve to the rear or plumb it all thru a factory disc prop valve.
