What do you mean by restoration block? A standard 340 block or the "restoration" block that was offered by Mopar Performance (similar to the R3 blocks)?How far would you feel comfortable in bore size on a 4 bolt main, 340 Restoration Block
59 on this one thow. But how do you know if it is a resto block?According to what I find this is a 48° short deck race block... not exactly a restoration block.
Do you have any pictures of the front of the block? any numbers cast in the front left or right side?
This is the pic i have. I know it is a R block, first gen.Do you have any pictures of the front of the block? any numbers cast in the front left or right side?
Well when i saw it i had an X block in the garage.cool, never saw this before with both lifter angles in the block casting…..any Chance there is another one where this came from? ;-) is it a 4 bolt on the middle mains?
Michael
Here is a pic from when i got it.I assume that since it's 4 bolt mains, it has filled pan rails, kinda like the 340 6pak blocks? do you have better pics of the bottom end? I assume the big "R" means race block
Those first R blocks were before mopar used the term restoration block. On shadydells website it is stated Mopar recommended up to a 4.080, but sonic checking it would be a good investmentcool, never saw this before with both lifter angles in the block casting…..any Chance there is another one where this came from? ;-) is it a 4 bolt on the middle mains?
Michael
Well i have allready bought some nice wiesco 4,04 pistons, eagle h beams rods and a eagle 4" crank. Going for w5 that i bought a couple years ago. Will be a all out dragrace engine.screw what MP said
just bore it to 4" first build with 360 crank
or 4" stroker
lots more piston choices
block will move around unless you have it heat cycled
you can bore more later
as said stronger walls make more power than a couple of cu in
If you already have a premium 340 crank then 4.040 std 340 first build
stroker is better even if your are road racing
hp is limited by heads and gear spread, you have to back off on the absolute hp to not bog on shifts, even at Bonneville which is really one long drag race
people ask what head
what rpm range do you want?
do you know what a 59* r3 will go to on average I know it depends on each block .I have a 59* resto block in the shop now. It's a siamese block at 4.190" bore, and can go to 4.220".
