[Found!] MC Offset Adapter
SSing
upland, sweden
Hi,
I´m looking for one off these...
Thank You
Stefan
I have one from Mancini racing.
It has a black anodized finish and two extra threaded holes for the modern two bolt master cylinders.
The anodized coating strips off very easy with 100% lye drain cleaner to match the bare aluminum look on the hurst bo29's.
The 2 extra holes are covered when a factory 4 bolt master cylinder is bolted on.
Thank you ssba, if you thing this will look correct on my build, save it for me...
I PM you.
