McLeod- big changes
396 Signet
Pittsburgh, PA
McLeod formerly sold a huge array of clutch & pressure plate applications and would make virtually anything if they didn't have it. Their technical support line was stellar. Unfortunately they were bought out by B&M a couple of years ago & all this has changed. They no longer offer anything custom & the only items available will be high volume sellers. As far as old mopar is concerned, only the 10.5, 11 inch, & dual disc setups are offered. Most of their extended lists of items shown on their website are actually not available & they have not notified their distributors either, Summit was as aggravated as me. This affected me directly as I wanted to use a 9.5" setup (early A) which got the ax. Their tech line is thoroughly useless unless you have the simplest of questions & are rude as well. Another fine American company down the tubes.
The same thing happened to Hurst when B&M bought them. Prices nearly doubled and selection was heavily trimmed.
Great, now where do I go when I want to get stuff to build up a 4-speed conversion? Screw McLeod and Hurst.
