Measuring pushrod length in Magnum engine
Siksty7 Dart 270
Ohio
I'm working on a stock Magnum engine with a reground cam. I'm measuring for new pushrods. What additional length do I add for proper preload at zero rod lash? Should preload be added to the maximum pushrod length at zero lash (valve fully closed and lifter plunger all the way down)?
Disregard, I found a video put out by Melling. I will be measuring the plunger travel dividing it in half and adding to the length of the maximum pushrod length at zero lash.
