Mechanical fuel pump question SB
Syleng1
Karma is real and Life is short...
North Franklin, CT
I’m looking for a small block fuel pump that is “factory looking” but has 3/8” inlet nipple and outlet nipple or flare fitting that fits a small block Mopar. Anyone know of such a beast?
“Yes!” I can go a Carter Comp series or Holley but they look aftermarket. I figured some one on here may know a pump part number for a forklift or industrial application where a Chrysler Small Block was the power plant but it needed larger fuel supply like a generator or travel lift or even a airport tow motor.
Thanks!
Joe
Buy the Carter and put the size fitting in that you want. It looks like stock to me, as it will to everyone else.
