mechanical rockers
72swingerwoman
Active Member
what is the best way to set rockers, tried the fella gauge thing today but i dont think that really works unless everything is new, and not broke in and used. or is there anybody in mn twin cities north west side that knows a mechanic that will come out to homes and help tune in a motor???
help help help help please!!!!
Sorry I'm nowhere close to help but things don't have to be new to set it right with a feeler gauge. I assume you must have a solid lifter cam, correct? Cause hydraulics set to zero lash. The main thing is you just need to have the engine in the turned to the right spot to set them. Here's a link to a chart that shows where to have the engine to set each valve.
http://www.moparts.org/Tech/Archive/motor/14.html
