[FOR SALE] Melling high volume oil pump
circlepilot
El Dorado, Arkansas
New, slant six, 198, 170, 225 Melling high volume oil pump. I had it installed on my short block and was convinced that I didn't need the high volume for my type of build. As said, the pump was installed, but never run. $40.00 + shipment.
YES! this is the pump, I thought I had a problem with the gear binding. after talking to Melling, I was made aware that I was turning the camshaft with the sprocket bolt and with out the timing chain installed. The cam was being pushed to the front of the engine and giving the feeling of a bind. However, I was convinced by others on here that I didn't need a HV pump. I put the original pump back on with a new gear and until I talked to Melling, got the same feel of a bind. I installed the crank shaft (no rods or pistons and timing chain and the binding went away, just like I was told that it would. If someone bought this pump and had a problem with it, I would make good on it. Your lack of a narrative in your reply "is loud and clear."
Pishta was just lettin me know you had one for sale because he knew I was lookin for one. The HV pump I need though is a six bolt pump with the rear cavity on it. I cannot use this one. It's a good deal for somebody though, as they are over 100 dollars new.
Thanks for the clarification. As there was nothing on my end that I would not stand by. Yes they are expensive. And I know that someone can use it.
Norm
