[SOLD] Meziere Electric Water Pump for Small Block
Rocket
U.S.A.
I have a newly rebuilt Meziere 35 gallon per hour electric water pump part number WP114U for small blocks. Included are the pump, water pump block off plate and two sets of new gaskets. The pump had not been run since being inspected and rebuilt by Meziere.
Price is $360 shipped in the lower 48 states.
What is the diameter of the lower hose fitting? Do you have the male pigtail connector lead for it? Also, what is the total depth (with backing plate) mounted: timing cover to the tip of the motor? Thx
The Lower hose fitting is 1.80" where the hose clamp attaches around and 1.88" at the front lip of the hose clamp area. The lower radiator hose screws in so other versions or adapters can be fitted. It is also possible to switch the lower radiator hose from side to side as they screw in to the housing. The other side has a screw in plug. The max distance of the water pump to timing cover housing is 6.50". I do not have the other end of the pig tail but that should be available at an auto parts store.
