Hmmm....calculator I just used said with a 26" tall tire, 1.00 final drive in trans, 3.73 gears at 70 you will be turning 3374 rpm. Same setup with a .75 final drive in the trans will yield 2531 rpm. To get to that rpm with a taller tire it will take a 35" tall tire....if you plan on putting a taller tire on it to kill the gear ratio care to guess what you are going to do to the effects of the 3.73 while accelerating? In order to get to the same rpm by slowing down, according to this calculator you will need to go 52 mph. No way I would be able to cruise at 52 mph while folks around me are going 70.....To me that is just going to be an accident waiting to happen...Good Luck with that....
Why are folks so hesitant to adapt any sort of technology beyond 1970 into these old cars? I get it that it is not cheap....then just buzz the thing 3400 rpm and live with the decreased fuel economy and the possibility of increased engine wear...not to mention living with the annoyance of 3400 rpm....
