My father passed away shortly after having this motor assembled in July of 2020. It's sealed up and tucked away under an engine bag, sitting on the oil pan rails on a wooden transport jig I made. The motor has never been run, all parts are brand new and never used / broken in. I don't know a ton about it, other than what the engine builder said.
Here is all the info I do have. A lot of part numbers and some background info from the shop (when I called they said they didn't keep a lot of records on it). If you look through my posts, you'll see I've been asking about this and researching since my dad passed. I'm trying to fund a build so I can get his Dart on the road again. I'm going the BB route too to honor his vision, but figured this would be too much to put on the street for me. From what I've gathered, it'd need appx. 4k stall and that's just too much for me.
If any well-reputed members can vouch for the shop or builder (if they know of them) I'd be extremely appreciative.
Machine Shop Notes:
Contact Info.
Discussion Notes:
Engine Components:
Connecting Rods
Main Bearing Set
Fel-Pro Valley Pan Gasket
Clevite Camshaft Bearings SH-876S
Ross Racing Pistons
Ross Piston Thickness Data
Ross Piston Rings
Mopar Performance Camshaft and Lifters
Miscellaneous:
Shipping or pickup from 22015 / Northern Virginia
Price: $5,500
Payment Methods Accepted: PayPal / Cash / Cashier's Check
Thanks!
Machine Shop Notes:
Contact Info.
§ River City Machine – Randy Barrell (has been great to talk to, ready to help answer what questions he could)
§ 802-295-5788 / rcmvt@hotmail.com
§ 71 N. Main St., White River Junction, Vermont, 05001
Discussion Notes:
§ Motor designed for race fuel / 110 octane
§ Motor has 12:1 compression
§ Worth appx. $6500
§ If used in current state, special cam break in procedure
· Over 2000 rpm for 30 minutes, then change oil and replace springs
§ Appx. 600 hp
§ Built to be a “hobby” racer, not for serious competition
§ Worth appx. $6500
§ Appx. 600 hp
Engine Components:
Connecting Rods
§ Scat Enterprises
§ Pro Sport H-Beam, ARP Bolts (7/16”)
§ Rod Length 6.760
§ Rod Journal 2.374
§ Wrist Pin 1.094
§ Big End Width 1.012
§ Rod Length 6.760
§ Rod Journal 2.374
§ Wrist Pin 1.094
Main Bearing Set
§ Mahle
§ MS-1039H-10
· High performance bearing (partial groove)
§ Crank’s been turned
§ MS-1039H-10
§ Port Sthye: Rectangular
§ Port Height: 2.270
§ Port Width: 1.230
§ Blocked heat crossover. 4 facing pieces. .030 thick.
§ Port Width: 1.230
§ Stock Cam Bearing oversize
§ Not grooved
§ Not grooved
Ross Racing Pistons
§ Bore: 4.350
§ Bore (mm): 110.490
§ Stroke: 3.750
§ Engine Stroke Type: Stroked
§ Rod Length: 6.768
§ Dome, with two valve reliefs
§ Forged aluminum
§ Compression height: 2.065
§ Piston head volume: -14.00cc
§ Wrist pin style: press-fit or floating
§ Pin diameter: .990
§ Stroke: 3.750
§ Rod Length: 6.768
§ Forged aluminum
§ 3.570 – A dimension (for Ross eng. Dept only)
§ 99501 – Ross Job Card / Part Number
§ GH – Program run by
§ .200 Deck thickness major front
§ .297 deck thickness major rear
§ .185 minimmum thickness under intake valve pocket
§ .182 minimum thickness under exhaust valve pocket
§ .272 minimum thickness at top of flat top / dome / dish
§ .297 minimum thickness of dome at edge on plug side
§ .185 intake vlave pocket to top ring groove
§ .169 exhaust valve pocket to top ring groove
§ .102 side relief
§ .125 pin hole to side of pin boss
§ .785 pin engagement in pin bosses (each side)
§ .102 side relief
Ross Piston Rings
§ Bore: 4.350
§ File fit, top ring 1/16 in thick iron
§ Second ring 1/16in
§ Oil ring 3/16in
§ Bored .30
§ Oil ring 3/16in
§ Bored .30
o P4120663
o Adv duration 312/312
o Duration @ .050 271/271
o Intake centerline 104
o Lift .590/.590
o OverLap 104
o Type – mechanical
o Bolt pattern 3
o Lift .590/.590
o OverLap 104
o Type – mechanical
o Bolt pattern 3
Miscellaneous:
Damper from 440source, but no other info on it
440 Source Aluminum Water Pump
Edelbrock Performer RPM Intake- Dual Plane
Previously sold carb but was an 850cfm double pumper
906 Heads. Shop said they rebuilt them and did all the valve work but couldn't remember if they were ported or not.
Price: $5,500
Thanks!
