Has anyone installed a Milodon windage tray with the Milodon stud kit after the block has been lined honed ? The customer I am building a engine for brought the Milodon oil pan, and a windage tray and stud kit. The block has been lined honed and has ARP main cap bolts. I already have the short block together, and I don't think if I put the factory main cap bolts on, the windage tray would clear the crankshaft. looks like it would be too close resting one the main bolts like the factory tray does. I don't have a factory tray laying around to check. This is a 1969 340 block with a Scat rotating assembly, 3.58 stroke crank.
