[FOR SALE] Milodon Small Block Gear Drive - Used
Rocket
CT
I have a nice used Milodon gear drive part # 13600 for small bock engines. This was used on my W2 headed 360 bracket motor. It provided rock solid ignition and cam timing. I was saving this for a future rebuild however I sold the car so this is no longer needed. All the gears and bearings are in great shape. Attaching hardware is included but not pictured.
Description from Summit Racing is as follows:
“Milodon timing-gear drive assemblies are designed for all-out competition, but work equally well in any application. Their proven fixed idler gear system is capable of maintaining consistent cam timing without siphoning off power the way 4-gear types can. Timing changes are easy via Milodon's adjustable bolt pattern cam gears and hub assemblies. Made for strength and durability, these gear drives will last indefinitely. They are available in a flat-cover style, which uses a stock-type water pump, or an injected/blown style, which doesn't use a stock-type pump.”
Price is $325 shipped in the lower 48 states. I will ship internationally for the added cost if any.
PM me with any questions.
