mini tub
DAWG 340
Port Charlotte FL,
i just finished mini tub my 70 duster. can any one advise me on how big of a tire i can fit in there also what type of backset on the rims. i plan to use cragers any help would be appreciated.
Are leaf springs in the stock location, on 3/4' offset hangers or moved into the frame rails?
I got 9" Hoosier slicks + sidewall bulges on a 10" rim to fit nicely in the wheelwell with 3/4" offset hangers. (no mini-tubs) I don't think you'll gain much without moving the springs.
Early on I had 10.5" bias slicks with 1" more rim width on the outside but I didn't like the sidewalls sticking out even though tread with was within the fender lips. Car isn't here but I have spare mounted wheels that I can measure overall witdth (sidewall buldge) and offset with the 9" slicks..
At least 13.1" section width, because that fits under a 69 dart and you don't have the quarter panel skirting the tire.
From a street perspective;
My stock 68 Barracuda tubs accept 325s with just the springs offset.
IIRC those are 13.6 profile on 10s , but 10s are really not wide enough.
Even my 295s on tens have to run down at 24psi for long tread-life. I got used to the rear steer and now I like it.
But, on the stock rear end location, at about 28"tall the front of the tire is getting a lil too close to the sheetmetal for my comfort, and spacers on the stock hangers are only good for maybe 3/8" more room. Some guys reshape that corner. So far, I've been getting away with the spacers.
> I'm pretty sure the Duster has the same size factory tubs. So just add
whatever the mini-tubs and springs in frame, gave you.
If it was me,
> I'd narrow the rear end cuz I like better, the deeper-dish look. and
>Cragars are pretty heavy for street, especially when you get to 10s or 12s..
> My alloy wheels weigh nearly half of what a steel Rally weighs. My back really appreciates the lighter wheels.
> FYI; 275/60-15s seemed as good as 295/50-15s, in straight line work.
But IMO, 295s are better for drifting, cuz with more sideways rubber, there is less drama and quicker/easier recoveries if/when I screw up... And 275s can be run on 8.5 wheels for lighter total weight, and can run 28psi for a long tread life and some say better street manners.
The biggest is 12 inch wide with a 7 1/2 back space
I'm thinking you mean 12" tread?
Ima thinking, that would be close to a 340profile; and, on the street, should probably be run on a minimum 11" wheel. I'm guessing.
I did mine on a 72 Dart which has less room than your Duster right out of the gate. I also relocated the springs to the frame rails, and I am using a stock width 8 3/4 as well.
I am running 325/50/15's on some stock cop wheels widened to 10" with a 7 5/8 backspace. They fit like a glove...
Agreed, you really want the tire on the widest wheel possible, or you are forced to run low tire pressure and you will get more sidewall flex with a narrow wheel, wide tire combo
I run 11.25" wheels with 13.1 section width tires. Just under 2" less than the section width.
You need a tire and wheel fitment tool. There are several on the market. I have one made by Percy's. It's been discontinued, though.
Everyone else's advise is purely just a close guess. Measure your car yourself. You have many variables and +/- tolerances to consider. This way you know for yourself you can get the maximum tire under there with no issues.
A '70 Duster should have close to 15" from the frame rail to the quarter lip, if it hasn't been trimmed/rolled already. So even allowing a 1/2" of clearance on the frame and quarter lip on a car with an untrimmed quarter you'd have close to 14" to work with for the section width of the tire.
The 3" relocation really makes a lot of space. 72BBswingers car had a 3" relocation and mini tub, he had 18x12's with 335/30/18's on it and said he still had some space. This is his car (was I guess, he sold it). But this is a Dart, and with nothing else changed a Duster will have an extra 1" of wheel tub space than a Dart does because of the wider quarters. So, 335's would be a piece of cake. Maybe 355's?
006-copy-jpg.1716276926
Backspace will be dependent on whether or not the axles have been upgraded to BBP or not and what rear brakes you're running. But a 12" wide rim should be easy. And that's without any trimming or rolling of the quarter. On my Duster, with a rolled flat quarter lip and quarter that was pushed out with the fender lip roller, I've got 16.5" from quarter to the outside of the frame rail.
