Misc. engine/underhood parts.
Locomotion
Florida
All parts price + shipping from 32117 in Florida.
Will be at the Daytona Turkey Run swap meet over Thanksgiving weekend inside Daytona Speedway.
* Childs & Albert Duramoly 5/64" File Fit rings.
RS-10477-25 for 4.020" bore
RS-10477-45 for 4.040" bore
$80.00 each
* Mopar Performance race coil P3690560 NEW - $40.00
* Mopar Performance race ballast resistor - 1/4 ohm - P2444641 NEW - $10.00
* Mopar Performance small block vacuum advance distributor - P3690430 - used - no cap but everything is loose and rotates smoothly. - $30.00
* Mopar Big Block header gasket ROL MS5938HT graphite type - $10.00
* OEM 360 harmonic balancer/damper - $20.00
* Dart/Duster underhood fender braces - $20.00
* Chrome fuel line for 4150 Holley carbs - used - double pumpers and vacuum with secondary metering blocks - $5.00 SALE PENDING
* Moroso brand electric water pump fitting - 1.5" - NEW - fits Moroso, Meziere, etc. $10.00
* Holley Adjustable Vacuum Secondary Pod & assorted springs - $20.00
* OEM E & B body motor mounts - appear new or used very little - $5.00 / pair
