dart540
727 Trans rear weight used $15 + Shipping
Gauge Holder 3-2 5/8 new $10 + Shipping
Msd RPM modules W/Case New & Used $90 + Shipping
3000-3000/4000,4200.4400,4600,4800,
5000,5200,5400,5600,5800,6000
7000,7000,7200,7400,7800,8000,9000.
MSD New #3320 replacement boots&terminals 2pk.$5.00 + Shipping
MSD New #8850 replacement boots&terminals 9pk $20 + Shipping
Mopar Small Block Bronze Dist Gear Used With New MP Intermediate shaft bushing $100 + Shipping.
MRE #220 Dist hole plug New $20 + Shipping.
MRE #AX42 Mancini Throttle Return spring bracket New $15 + Shipping.
MRE #1060 Mancini throttle return kit Big Block New $25 + Shipping.
MP #P4349629 Chrome Dip Stick & Tube New Big Block $18 + Shipping.
Mr Gasket # 4367 Hi Perf Thermostat Big Block 180 Degrees New $15+Ride
Moroso # 71410 New quarte turn springs 1 3/8 .375 spring height 10pk
$10 + Shipping.
Used stock pinnion subner $10 + Shipping.
Used Accell coil $ 10 + Shipping.
Used Stock throttle bracket $ 15 + Shipping.
K&D #2324 New brake lining gauge $10 + Shipping.
K&D #2116 New Disc brake lining wear gauge $5 + Shipping.
Used eng braces from trans to motor small blk $20 + Shipping.
New Ballest Resistor $5 + Shipping.
Used Autometer 2 5/8 volt gauge $15 + Shipping.
Jegs New #100485 hose fitting 3/4 NPT to 1in hose $12 + Shipping.
Meziere # WP-1175B Used 1in NPT to 1 3/4 hose $10 + Shipping
Summitt New #SUM-MSM12 rod end 3/4 in.-16 RH Male Thread 3/4 in. bore Mild Steel w/Jam Nut $25 + Shipping.
Used Mr.Gasket 2in. 4-Hole Alum Spacer $15 + Shipping.
New Jegs #555-10314K Jumper Terminal Mounting Bracket Kit $35 + Ride.
S&W New Fuel Pump Bracket fits Holley Blue Pump or BG #200/400 Series Pumps $15 + Shipping.
Thanks Stan.
$10 + Shipping.
Thanks Stan.
