416 scamp
Going to race this weekend for the first time in 4 years.... Change plugs and wires.... still has a miss at 3000 rpms... What you guys think it is?
Car has sat for 4 years also... got it back on the road 2months ago
Has the miss been there ever since you got it running again? Reason i ask is besides the fuel system, what else comes to mind is running the times in you signature i'm pretty sure you have a decent size solid cam in it. If the rocker shafts were installed the whole time it sat, several of the valves would have been in the open position and could have weakened a few valve springs.
Is there a way to test seat pressure with the heads installed on the car?
Just realized this question. For me the answer is yes and no. I've used a tool similar to the one pictured below. As far as testing a unknown spring i don't believe these are accurate enough. What i did was bench test for the proper tension and right after installation i ran them with the tool to get a number. Didn't really matter what the tool showed, i would document whatever the readings were for later. Then whenever the valve covers were removed or i suspected something was up i would do a quick run thru to confirm whether any pressure was lost or inconsistant.
Does that tool attatch to the rocker arms, or do you have to remove them? I saw one in Jeg's with a dial gauge, kinda pricey though.
