missing at idle
MOUSE
GLENDALE AZ
I have a 94 5.9 that surges when at idle. changed intake gaskets , plenum gasket , tb gasket and all of those dumb *** plastic vacume lines and the T's. the idle sensor and the other sensor that I can't think of the name and it still runs like ****. a little better but not right . any fresh ideas would help .. ALOT :banghead:
Did you clean the throttle body when you had it apart? Try that and make sure you clean inside where the idle air motor goes.
