challenger57
cuda57
When setting pinion angle should the car be on jack stands under the frame letting the suspension hang or should the car be up on blocks. I have checked my angle with car on blocks under tires and I get tranny down 1.5 degrees and with 2 degree shims the pinion is up 1 degree. This all comes from after doing a auto to 4 speed conversion. After doing conversion I had a thud when starting to back up. One person said needs new leaf springs, did that no help. Another said pinion angle, hense the 2 degree shim. That almost got rid of it but does it still slightly. I have another set of 2 degree shims and was wonder about trying them but then pinion will be up 1.5 degree more than tranny. So what is correct method and thoughts on degree difference.
