Moog 7103's
moparmarkk
milton,fl.
Hi ,just got a set of 7103's from rock auto,inside each box there is a metal washer that is dimpled, what are they for? thanks mark
They press into the eye of the bushing from either side.
Putting them in the freezer and then pressing in with a vice works pretty well.
it goes over the bushing and acts like a wash between the bushing shell and the mounting tabs on the frame. the "dimple" indexes the thru hole in the bushing. they're a light press fit into the inner metal shell of the bushing.
there should be 4 per set, or a "washer" for each side of the bushing.
