alyak
Active Member
Can anybody tell me if these are performance pistons in my 360? Or how can I tell? Do I have to remove them?
READ my response above. If they are forged, they are stock replacement. I don't know what's unclear.If they are aftermarket forged will the engine be the same compression? I am guessing so since you said stock replacement. Also, do I have to remove the cam to be able to tell if it is aftermarket or stock?
This is what I’m expecting you’ll find stamped on top. Stock replacement forging.
L2405F .030 OVER TRW FORGED PISTON SINGLE 360 CHRYSLER | eBay
As far as camshaft goes, measure the lift with a dial indicator from the top of the lifter without the pushrod in place and report back. Keep in mind that the lobe arrangement front to rear is Exh. Exh. Int. Int. Int. Int. Exh. Exh. Exh. Exh. Int. Int. Int. Int. Exh. Exh. when positioning the indicator.
Stock replacement forged. Those are nice. They are heavy compared to what's available today, but they are darn near indestructible. I'd clean them up and run hell out of them unless the block needs boring.Ok, you are right. That’s exactly what is stamped on them. They are TRW forged .030 over
Unless it had .010" wear, I'd get file fit rings and run it anyway. It'll rev like a ***** in church.And if the block does need bored but the pistons aren’t scuffed up or badly worn, it’s usually not hard to find a buyer for them, either.
They gotta be swappin holes before I'll bore it. LOLAbsolutely!
