[SOLD] Mopar 727BB Transbrake transmission
dart540
south western PA.
Rating - 70%
7   3   0
727 Big Block racing trans A&A transbrake with low band apply,Billet steel drum with billet retainer and 15-1.4 springs,A&A Wide Solid Red Racing KD Band,5-thick red racing clutches/steels,frt drum 4-red racing clutches/steels rear clutch,with chrysler factory stock HP input shaft,steel spacer ring and modified piston /spring,lightened sun gear,rear drum.rear clutch,rollerized rear support,alum spacer in place of gov housing,A&A red racing rev band,bolt in sprag,deep steel pan,4-pinion alum planet frt/rear,76-up later intermediate shaft,new pump gears,babbit front pump bushing,vent blocked moved to rear,billet rear servo,acc.blocked,70 frt servo with #65 springs,modified case for converter access,oil mods to internals/case,teflon sealing rings.
$2,650 free shipping pm for details/pic.
Inbox is full, want to talk to you about a similar build in a sb case. Message me
