[SOLD] Mopar 833 Hemi 4 speed Hydraulic throw out bearing
Swingin1970
Santa Barbara CA
HYDRAMAX Hydraulic Bearings
SPECIFICATIONS
AWR-CACH30006HM
Pre-bled for easy system bleeding
Pressure tested for reiliability
Double width Buna-N seals – long lasting, can be stored for extended time without failing
Compatible with most domestic 4, 5 and 6-speeds
Brand New for 833 18 spline Hemi 4 speeds and Fork TKO manual transmissions.
Retails close to $700.00
Asking $375.00
Will this work with a 23 spline trans? If so I will take it. Thanks, Clint.
This TOB is for the larger 18 spline bearing retainer. You could easily fab up a spacer tube to go over the smaller 23 spline bearing retainer.
