jtkaaa07
BossMan
If your dropping a Big Block and a 4 speed in your A Body , this is the bellhousing you will need to do it, part number 2468372 is also correct! It was beadblasted , threads checked, and painted. This bellhousing is for a 10 1/2" clutch with 130 tooth flywheel, and has the 4.354" bearing retainer diameter . The bellhousing is cast iron, these are getting extremely hard to find, don't hesitate, this one is as good as you will find! Just order correct clutch fork, and Z bar from Brewers Performance, and your ready to roll! Asking $275 plus the ride, located in central Wisconsin, I also have it listed on Ebay, but have it discounted on here.
Thanks Jeff
Thanks Jeff
