OK, so what happens if you use the wrong one? I have had a spare '69 cap on my 1980 Dodge D200 pick up, for the last twenty years!
You have a 70 tube on your car. Yes the cap will work from a 72 on a 70 car. You may find that if you turn your cap tight the handle may be crooked. Other then that the only difference is the cap you have is vented and your tube is also. Not a bad thing but not correct. A 67-70 cap will not fit a 72 up tube. The prongs on the cap are to wide. But as said you can go the other way without much effect.I just stumbled across this thread. I have an early 71 Demon SPD 925 but from your reference pictures I have the 72 and up cap with a filler tube that screws in from the back and my cap sits perfectly.
My filler tube has 3 screws and a vent line that is just sitting open under the trunk floor.
Oh and before we start a stripe thread I realize the cap should be painted including the handle and the stripe moved up accordingly.
Any thoughts?
Thanks
Ron:burnout:
OK a 70 tube and I see it is a newer cap.
I guess the real question is since the car is a 925 build is the tube correct for my car? I have to look again but I'm 99% sure I don't have the 71 one year tank also.
Ron
