[SOLD] Mopar Disc Brake Spindles 73 74 75 76 A & E Body Dart Valiant Cuda Challenger
hemi71x
hemi71x
Rancho Cordova, CA
These are a pair of disc brake spindles that are officially used on 1973-74 Barracuda's and Challenger's, (E body cars) and 1973-76 Dart's, Valiant's, Duster's, Demon's. (A body cars) These officially came off a 74 Plymouth Valiant.
They are the spindles with the larger inner wheel bearing diameter, and are the sought after spindle to do the larger 11 3/4 inch rotor disc brake upgrade on 1962 -72 B body cars, 1970-72 E body cars, and 1972 and earlier A body cars.
These spindles have the correct overall height measurement to readily interchange on A, B, E, body automobiles. For you 1972 and earlier A body guys wanting to convert to the larger 4 1/2 inch bolt pattern wheels and brakes, you will need to change your upper control arms to the 73-76 version to use these spindles.
I cleaned the spindles, all the nuts and bolts, of 35 years worth of grease and grime, and then soaked them off in a solution of a product called Evaporust to remove all the surface rust from the spindles. Parts are in great condition, Ready for use. This listing is for a pair that i found last week when i made my wrecking yard rounds. So this now is my last pair that i have in stock.
You get everything in all the pictures, all the mounting bolts & nuts, bearings, seals, spindle nuts and washers, everything off the donor vehicle, which in this case was a 74 Plymouth Valiant.
So, you don't have to spend another fifty dollar bill at the parts store, purchasing missing parts and hardware, i include everything in my sales. This current listing is for a second pair, that i came across this past weekend.
$200.00 + FEDEX'ing to your zip code + 3% Pay Pal
Price is "firm," not interested in trades for anything, or "offers" than the stated listed, price.
Send me a PM, and we can go from there.
Jim V.
I'll pay $160 shipped to 89701.... that should set the bar.
I'm real and I pay fast.
Jeff-
