[SOLD] Mopar DISC Brake Spindles 73-76 A Body Cars
hemi71x
Rancho Cordova, CA
These are a pair of disc brake spindles that are officially used on 1973-74 Barracuda's and Challenger's, (E body cars) and 1973-76 Dart's, Valiant's, Duster's, Demon's. (A body cars) These officially came off a 74 Valiant.
They are the spindles with the larger inner wheel bearing diameter, and are the sought after spindle to do the larger 11 3/4 inch rotor disc brake upgrade on 1962 -72 B body cars, 1970-72 E body cars, and 1972 and earlier A body cars.
These spindles have the correct overall height measurement to readily interchange on A, B, E, body automobiles. For you 1972 and earlier A body guys wanting to convert to the larger 4 1/2 inch bolt pattern wheels and brakes, you will need to change your upper control arms to the 73-76 version to use these spindles.
I cleaned the spindles, all the nuts and bolts, of 35 years worth of grease and grime, and then soaked them off in a solution of a product called Evaporust to remove all the surface rust from the spindles. Parts are in great condition, Ready for use. This listing is for a pair that i found last week when i made my wrecking yard rounds. So this now is my last pair that i have in stock.
$175.00 for the pair + whatever the shipping to your zip code, thru the FEDEX guys.
Send me a PM, thru this forum.
Jim V.
