68dodge
Anyone ever try the Mopar Gold ECU for racing? Is worth trying out. Had a Rev-N-Nator the worked good but it would not start my car after 4 times.
I believe a previous post mentioned an older mopar performance catalog.
The gold box ecu was sold with recommendations to use a specific accel coil ( not the big yellow one) and 1/4 ohm resistor. It is supposed to be a package deal. The 1/4 ohm resistor Is not the same resistor that is recommended for the orange ecu.
I used the entire recommended package. When mounted close together, my car ran also but it did not run clean and was down on power. You have the high voltage spike from the coil interfering with the low voltage trigger pulse. As always ymmv.
But the ecu runs like a scalded dog as high as I cared to rev my motor.
Great throttle response.
Duane
