[SOLD] Mopar Electronic Ignition Distributor B-Engine Plym Dodge 383 / 400 NOS Cap
MidnightSwinger
Woodland CA
Brand new in the box, going with a full MSD setup instead. Includes an extra USA cap with brass contacts. $110 shipped.
for Mopar Electronic Ignition Distributor B-Engine Plym Dodge 383 / 400 NOS Cap | eBay
Will, do you know the advance curve on it?
Pulled this from the ad:
had it made as a duplicate of the 440 A-134 hi-po specs, true 2-stage springs, a true street performance curve:
Less than 4 deg. mechanical adv. below 650 RPM (for cranking)
approx. 8 deg. at 950 (fast idle)
Approx 13 deg. at 2500 (HP)
Vacuum: near-zero at 10" vac, then 9-10 deg @ 15" (fuel economy / no oil dilution)
Note that these numbers are all DISTRIBUTOR degrees, double for crankshaft degrees.
And it looks like it is adjustable like a malory also! If I didnt have a few I would jump on it!
