[FOR SALE] Mopar electronic tach drive distributor
737jetdr
Martinsville, In.
Part number 4120942 . For big block 426,440. I will include the mopar adapter kit to make this fit a 383 & 400.Worked fine when removed. Asking $290 + shipping. $250 without 383/400 adapter. Wires have been repaired. Soldered and heat shrink.
You are going to have to make up your mind what that fits, because a 383/400 dist. is shorter than a 413/26/440
Next step would be to accurately measure the shaft from the mount to the end and start a thread in the "regular forum" and get someone to confirm shaft length. Either someone has swapped the shaft or the tag, one or t' other as they don't fit "both"
313/26/440 and hemi are all "raised" blocks and all take the longer shaft. I do not have the dimensions
